exhaust advice
Old Apr 28, 2006 | 07:18 PM
X___nothingspecial's Avatar
Default exhaust advice
i was curious if anyone has ran dual exhaust on their 1994-97 accord...
did you just split it from the cat? or did you split it just out of the header then put two cats...
would it get better flow with it split just off the header then two cats or keep the one cat?
i dont think it would make much of a difference would it?
and i was also curious if anyone has ran dual HKS mufflers...
any advice... please
thanks beforehand
Old Apr 28, 2006 | 07:49 PM
sir_nasty's Avatar
Default RE: exhaust advice
I would guess that running dual cats would be the better approach because your cat is a 'choke' point of sorts and will slow the flow of exhaust prior to the mufflers but if you had dual cats they could both handle it better/more effeciently.... but this is just a guess I have no personal experience with it and I could be wrong...
Old Apr 28, 2006 | 09:07 PM
well thank you for your opinion
that sounds about right...
Old Apr 28, 2006 | 09:23 PM
legionofone's Avatar
thats a negitive... get a SINGLE high flow cat... dual cats take atleast a v-6 u have to be able to get those cats up to 1400 degrees for them to start working... u actualy DONT need to split ur exaust... but if u do... run SMALL tube... 1-1.5 inch tube off of a 4 banger... u need to keep it small and keep it hot... think of it this way... if ur running a 4 inch pipe out of a 4 banger the engine has to fill all that pipe before it gets out... so yeh anyway... if i can help u with anything else just ask o yeh and cats make back pressure and that makes torque
Old Apr 29, 2006 | 02:09 AM
well really would you need the cats to actually work when you dont have emissions tests...
i dont have to go through inspections so...
sorry if i sound stupid im new to all this
mayot
May 12, 2012 08:49 PM
MountainMan99
Sep 4, 2011 07:08 PM
lappy35
Aug 25, 2009 09:43 AM
Oleander
Dec 6, 2006 07:24 PM
