Header Installation Help
Old May 11, 2007 | 10:47 AM
sssexy70's Avatar
Default Header Installation Help
Ok... so I'm a loser... I research everything so in depth before I even touch my car... and heres the thing... are stock gaskets reuseable in installation of new headers? I'm on the fence of which headers to buy... the dc sports don't say anything about coming with gaskets and the obx gaskets are crap, and i'm having a hard time finding gaskets that I can purchase from whatI think is a reputable canadian site...
What should I do to assure the most reliable purchase and installation?
Old May 11, 2007 | 11:21 AM
sir_nasty's Avatar
Default RE: Header Installation Help
The stock gaskets are not reusable. I'd either contact a honda dealership (last resort) or just try to find one at a local parts shop or you can always call DC Sports and see if they would sell one...
Old May 11, 2007 | 12:20 PM
poser_pilot6
I would assume (although I hate doing that) that the DC Sports header would come with gaskets. Find a reputable seller of the DC header, call them and ask. If not, I dont see why you couldnt find a good gasket online, or you could make your own if you get a sheet of gasket material.
Old May 11, 2007 | 06:45 PM
sssexy70's Avatar
See, I really don't want to blow a gasket so I'd really love to find something that I can buy as one set and rely on... are the megan headers good? Will they come with good gaskets for a little more money thanthe obx?
Old May 11, 2007 | 08:20 PM
19Accord97
My OBX gaskets lasted for 8 months...but that was without retightening them so that was part of the problem. Anyways, just order one from your Honda Dealership as it should bolt up. The only gasket you'll need to look for online if the one where the 2 pieces of the headers meet. But you could put some red high temp silicone on both sides of it.
When I replaced both of my gaskets I usead a Felpro from Autozone $9 then bought a big sheet of Mr. Gasket gasket $10 (it was the smallest size it comes in but its good stuff and can easily make 3 more gaskets if I need them), and red high temp silicone $3. So I replaced the ones where they meet the engine, then i traced the old gasket, cut it out, put red high temp on both sides, tightened it until the red silicone comes out, let it sit an hour, then compeltely tighten it down.
Then you'll HAVE to tighten down all the nuts/studs at least once a week for a month or two. Then they will loosen less and less.
Old May 11, 2007 | 08:56 PM
sssexy70's Avatar
So for the first few months i should tighten them often and I'll be fine?
Old May 11, 2007 | 09:23 PM
19Accord97
You should be. I am assuming that is why mine blew out. But if I had to do it agian, I would just use different gaskets just to be safe.
Old May 12, 2007 | 07:43 PM
sssexy70's Avatar
I've bought the obx now... I'm going to use the gaskets that come with and tighten them once a week for the first few months and hopefully they'll last at least a year... i'll also buy a spare gasket from honda just in case... but will blowing the gasket damage anything in my car? or is it something that can be replaced after a short distance of driving?
Old May 13, 2007 | 03:05 PM
19Accord97
Sounds good man.
You will be okay to drive with a blown gasket. I drove mine for about a week. It can be hard on your 02 sensors and your gas mileage will be cut by about half.
thunder_x
Sep 2, 2007 02:58 PM
mck52689
Jul 24, 2007 02:27 PM
sssexy70
May 19, 2007 12:15 AM
Slusher
Sep 29, 2006 06:44 AM
Jm
Sep 28, 2006 02:50 PM
