is my intake making me run lean?
Old Aug 19, 2007 | 06:41 PM
badxdawgx818's Avatar
Default RE: is my intake making me run lean?
Hey 97 accord does that work for the Maint Req lights?
Old Aug 19, 2007 | 08:31 PM
Velocifero's Avatar
ORIGINAL: badxdawgx818
the easiest way to reset the ECU is to pull the ECU fuse and backup fuse for like 10 minutes. then start it up like 19Accord97 said. i have to use this method because if i disconnect the battery at all, my backup alarm goes off. his way works too of course..
Old Aug 20, 2007 | 08:09 PM
oh ok i try it yesterday, i unplug the neg bat but when i turn on my car the Maintaince light still on why?
i unplug it for around 5 min
Old Aug 20, 2007 | 08:10 PM
could that be the problem unplug for 5 minutes?
Old Aug 21, 2007 | 12:25 AM
Velocifero's Avatar
bro, look in your owners manual on how to reset it. on 5th gens you just stick your key in the slot in the gauge cluster. if you still dont know how, drive to a Honda dealership and they will tell you how. this is really simple.
Old Aug 21, 2007 | 10:13 AM
00AccordLX5spd's Avatar
Registered User
badxdawgx818
To reset the Maint Req light on a 98-02 do the following: Get in the car, press the trip/reset buttom on the dash at the odometer, turn the key ON but do not crank the car yet. The Maint Req light will go off after you have been holding the trip/reset button down for a few seconds. When the light goes off, crank the car. You're done until the light comes on again in about 7,500 miles or so. Oh Yeah....[sm=icon_rtfm.gif] This is all in the owner's manual as Velocifero said.
Old Aug 21, 2007 | 10:16 AM
  #17
Registered User
bluelight
We need to know if you are referring to a "Check Engine" light or a "Service Required"/"Maintenance Required" light. There is a huge difference between the two.
Old Aug 21, 2007 | 12:00 PM
  #18
Thanks bro
RobinsonRicer
Apr 1, 2013 12:42 PM
msproles
Jan 22, 2012 09:19 AM
CrzyHopper
May 20, 2011 08:25 PM
asilomar244
Sep 2, 2008 05:01 PM
cheegum
Apr 7, 2008 08:22 AM
