Noise coming from exhaust shield?
Old Aug 13, 2009 | 08:58 AM
katjam
Default Noise coming from exhaust shield?
I have a 1994 Accord EX sedan w/manual transmission. I have a noise that occurs around the 1500 to 1800 RPM range. It has been suggested to me that it could be coming from an exhaust shield. I am curious if anyone else has had this problem and what the fix might be.
It is quick rattle sound, but it is kind of loud, so it is a little embarrasing leaving the house in the morning.
Old Aug 14, 2009 | 07:57 AM
vtecHef's Avatar
could be as simple as a heat shield making contact with your exhaust pipe. Got any way to get her up in the air? Usually the local shop can get rid of them for pretty cheap... (assuming that is the problem)
Old Aug 14, 2009 | 10:43 AM
lairdylairdy's Avatar
my 97 lx makes a slight rattle at around 1700rpm's. for mine it was just a heat sheild rattling slightly. sounds like yours is louder, but i'm sure it's the same problem
Old Aug 14, 2009 | 12:18 PM
Check out the heatshield first. If that doesn't do it, there's another possibility.
The "A-pipe" is the 2-into-1 exhaust pipe that starts from the manifold, & goes under the oil pan.
Certain years (not sure which) the A-pipe was a double-wall thing, and the inside pipe would buzz against the outer pipe. That drove me nuts on a '95 Integra because I thought it was a heatshield.
Alone
Sep 29, 2014 04:48 PM
ajohnson
Feb 20, 2014 09:47 AM
sp33dd3mon343
Mar 23, 2012 06:34 PM
Peli
Jul 18, 2011 10:12 AM
Drpepper
May 23, 2007 10:03 AM
