Test Pipe!
Old Apr 20, 2009 | 11:05 PM
19Accord97
Default Test Pipe!
Yes, I am thinking about getting one!
My mileage sucks and I think my cat is beginning to get clogged and w/ the price of titanium and other precious metals rising, cats are expensive.
Anyways, just wondering if the heat shield that fits over the oem cat will fit over a test pipe? Also, I have removed my header/downpipe before but rounded out the nuts. Will I need to torch the bolts to the rear of the cat assuming they dont round out?
Also, what do I need for the o2 tricker?
Old Apr 20, 2009 | 11:08 PM
I would just bring your car to a exhaust shop, tell them to make you a test pipe with a o2 cheater. Cost me $40.
Old Apr 20, 2009 | 11:12 PM
finch13's Avatar
A test pipe shouldn't need a heat shield, it doesn't have a catalyst that ignites. Plus, I think there is another heat shield attach to the bottom of the car above the heat shields surrounding the cat heat shields.
Just have them put an O2 bung in it, and then go get a pack of 2 18mm spark plug defoulers, drill one out with a 1/2" drill bit and go to town!
Old Apr 20, 2009 | 11:25 PM
19Accord97
I have been to a ton and all of them refuse to touch the cat other than to replace it.
I just wanted the shield for the oem look.
2 18 mm spark plug defoulers, so how does that work? I put these things in and then still put the o2 sensor in. I am a lost newb.
Old Apr 20, 2009 | 11:36 PM
finch13's Avatar
Who looks under your car? Do you have inspections?
The defoulers take the sensor out of the exhaust stream, so it sees a cleaner exhaust and doesn't throw a code. The sensor is too big for the first defouler, so you have to drill it, then put the second one on it... it's like a bung extension...
I make joo a deal. If you buy a test pipe, I send joo a homeade defouler for however much they cost, then less work for joo? I include funnay instukshuns.
Old Apr 20, 2009 | 11:42 PM
finch13's Avatar
Here r pix:
Old Apr 21, 2009 | 09:39 AM
g22cd5's Avatar
Supper Moderator
I will sell you BOTH of mine off my 94 cd5 if you want them. One of them is almost bran new and the other one Im not sure on its still on the car. Its a donor car so the cars arent being used. PM me if you want and we can work a deal.
*Note they will have to be welded in place they dont have the flanges*
Or you can pick up a high flow cat off ebay for like 50bucks.
Old Apr 21, 2009 | 10:03 PM
19Accord97
Thanks for the offer g22!
I'll just get one for like $32. Since the bung is not pre-drilled I plan on just extending the o2 sensor wire and assuming I get a header, I will just screw it into the down pipe w/ the defoulers.
Old Apr 21, 2009 | 10:11 PM
g22cd5's Avatar
Supper Moderator
anytime bro!
cavemantitan
Jun 5, 2013 12:19 AM
clutch811
Jun 20, 2008 08:46 PM
tnguyen600
Jun 5, 2008 12:36 AM
badxdawgx818
Jul 24, 2007 09:03 PM
02BlueAccord
Jan 14, 2007 08:51 PM
