is your check engine light supposed to go on after installing an intake?
Old Feb 7, 2007 | 12:32 AM
thunder_x's Avatar
Default is your check engine light supposed to go on after installing an intake?
my friend knows someone who has a short ram intake on his integra and he says his light is on because of the intake
could it be from bad installation?
Old Feb 7, 2007 | 12:36 AM
19Accord97
Default RE: is your check engine light supposed to go on after installing an intake?
He probably just needs to reset the ECU and let it learn with the new intake. Make sure there arent any leaks too
Old Feb 7, 2007 | 12:38 AM
thunder_x's Avatar
did you have to reset your ecu after installing your AEM sri?
cause im also thinking about getting an AEM sri pretty soon
Old Feb 7, 2007 | 12:43 AM
stevent's Avatar
i installed mines and the check engine light didnt come on, dont know why though. but you have to reset your ecu because your car is sucking up more air than your stock intake.
Old Feb 7, 2007 | 12:57 AM
thunder_x's Avatar
how about an aftermarket ecu?
would that be the same as resetting it?
Old Feb 7, 2007 | 12:59 AM
19Accord97
I reset mine just to be safe. It should be the same even with an aftermarket ecu. My light never came on after my intake. Just unhook the battery, open the doors for about 10 minutes, and then start the car, let it idle for 5-10 minutes and drive normally.
Old Feb 7, 2007 | 02:41 AM
kevin_nguyen0862's Avatar
minds actually went on also.... i was just told to drive for a certain amount of miles and then go the light would turn off and it did!!
Old Feb 12, 2007 | 11:00 PM
andywaco2
I have an 04 accord and I had this same problem. If the accord is year 00-07 he needs to make sure he kept the intake air temperature sensor and put it into the new intake. When i took apart my old one i accidentally threw away my old IAT sensor and had to buy a new one from autozone for like 33 dollars. There should be a hole in the intake that plugs in then u connect the sensor. I glued mine into the whole with silicon and after bout 15 miles of driving the engine light turned off.
Old Feb 12, 2007 | 11:51 PM
poser_pilot6
ORIGINAL: thunder_x
No, an aftermarket ECU is a completely different animal. The easiest way to explain it would be to say that resetting the ECU is just like turning the power to the ECU off, and then turning it back on. That way the ECU can "relearn" your cars characteristics. And a much easier way to reset it is to remove the back up fuse for about fifteen seconds. You should do that after every mod you make, just to be safe and make sure everything works the way it should.
sweet
Oct 24, 2011 10:48 AM
mjr.bonez84
Nov 22, 2010 08:49 PM
meliz
Jul 15, 2009 10:58 PM
thunder_x
May 1, 2007 03:36 PM
