2003 Honda Accord
Old Sep 24, 2020 | 11:56 AM
2003HondaAccordLX's Avatar
Exclamation 2003 Honda Accord
I am having an issue tracking down the problem with my Honda. The check engine light was on in my car so I had the code read on the machine. I was showing low voltage coming from the alternator so I replace it. The AC worked good before the alternator replacement but after the car seems like it idles rough after I turn on the AC. The engine loses RPM's like it wants to stall out. I had my mechanic come over to the house with the scanner from his shop and it threw the MAP sensor code. I went and got the part and replaced it. I disconnected the battery for a bit and then put it back on and drove it around town. The same problem when you flip the AC on ( RPM's bog way down to almost stall out ). What could be my issue? I am mechanically inclined but I am at a loss here and don't want to take this to the dealer. Yes I did check the belt alignment from when I did the alternator an everything matches up.
Casper Young
Jun 13, 2019 05:07 PM
alsdock
Apr 28, 2016 12:43 AM
93 Accord Driver
May 30, 2011 11:02 AM
JWittich
Nov 2, 2009 10:30 AM
wapunga
May 1, 2007 01:34 PM
