2007 accord 5 speed manual issue getting into reverse
Old Nov 17, 2020 | 03:33 AM
Kzoe240's Avatar
Default 2007 accord 5 speed manual issue getting into reverse
Anyone ever have this issue? Wont go into reverse when shifted in the car. But if i go under the hood and manually move the linkage were the shift cables attach goes into reverse easily. I just put in new shift cable bushing hoping it would help/fix the issue but it didn't.
Old Nov 17, 2020 | 08:04 AM
shipo's Avatar
Can you get the transmission to go into reverse via the shifter when the engine is off?
Old Nov 17, 2020 | 02:04 PM
Kzoe240's Avatar
No i have to open the hood and put it in reverse at the shift selector.
Old Nov 17, 2020 | 02:10 PM
shipo's Avatar
Sounds like your linkage is either broken or seriously out of calibration.
Old Nov 17, 2020 | 02:19 PM
Kzoe240's Avatar
it goes thru every gear fine except 2nd feels mushy when i try to shift it at high rpm. Looks like im going to need a new set of shift cables.
Old Nov 17, 2020 | 07:55 PM
You've looked at the shift cables attached to the transmission, but have you looked at the other end where they attach to the shift lever? You're going to have to get in there to change the cables anyway, you may as well figure out whether there's anything else you need around where the cables are attached in the console.
Old Nov 17, 2020 | 08:09 PM
Kzoe240's Avatar
Took the shift boot off when i was trying to get it in reverse. Looks like if the shifter could go back a quarter of an inch more It would in reverse. But thats as far as it can go. And the cables have no adjustments that i can see.
schaicho24
Sep 15, 2019 04:37 PM
Brooklynn Justin Obert
Aug 24, 2019 04:22 PM
Jonandbrandi Stancy
Apr 9, 2017 06:29 AM
WildAccord88
Apr 3, 2011 10:20 AM
superstition
Sep 1, 2006 07:43 PM
