2007 accord 5 speed manual issue getting into reverse
Anyone ever have this issue? Wont go into reverse when shifted in the car. But if i go under the hood and manually move the linkage were the shift cables attach goes into reverse easily. I just put in new shift cable bushing hoping it would help/fix the issue but it didn't.
it goes thru every gear fine except 2nd feels mushy when i try to shift it at high rpm. Looks like im going to need a new set of shift cables.
You've looked at the shift cables attached to the transmission, but have you looked at the other end where they attach to the shift lever? You're going to have to get in there to change the cables anyway, you may as well figure out whether there's anything else you need around where the cables are attached in the console.
Brooklynn Justin Obert
Aug 24, 2019 04:22 PM
