92 Honda Accord sucking me dry
Old Jul 7, 2006 | 03:22 PM
scandalus
Default 92 Honda Accord sucking me dry
Hi folks,
I have a 92 Honda accord that sat around for approx. 1yr. I recently brought the car back on the road. I did a tune up (plugs, wires, filters the works). My AC was working fine for a few days then all of a sudden it stopped. I checked the belts and found the AC compressor belt broken. This is the same belt that drives the alternator, so now I'm dead in the water b/c the alternator is no longer charging the battery.
I had the belt replaced, and the everything worked fine for a day then the AC went out again.
I checked the belt and its fine, except for the belt is moving extremely slow compared to the power steering belt.
I had a mechanic look at the problem and he suggested replacing the alternator. I did that and the same problem still exists.
I've already spend a fortune on this car and its getting worst. Would anyone happen to know what my next move should be or what the apparent problem is ?
Thanks for your help.
Old Jul 7, 2006 | 05:11 PM
mbo1985's Avatar
Default RE: 92 Honda Accord sucking me dry
Check the A/C compressor. Is it possible it seized and is causing the belt to drag?
Old Jul 7, 2006 | 06:58 PM
sir_nasty's Avatar
I'd agree... Sounds like your A/C is causing the issue... You can try to get a belt for a car without A/C and skip the compressor, get a new compressor or a junk yard take off and/or start some diagnosing... The cheapest fix would be to get the Non-A/C belt and put that on and go without it. Or go to the search up top and type in "free Manual" and you'll find a post that contains a link to get free manuals that you can use for more advance trouble shooting/proper diagnoses...
Old Jul 7, 2006 | 08:39 PM
Hello New Member..Thank you for joining up with HAF.
Sorry to see your having trouble with your Honda Car.
Old Jul 9, 2006 | 04:42 PM
accordlowered04's Avatar
welcome to the forums....i think your a/c compressor might be messed up...check that out and work from there.
Old Jul 10, 2006 | 08:08 PM
scandalus
Thanks to all you guys for responding,I appreciate. I'll have the AC compressor checked out and go from there.
Thanks.
Old Jul 11, 2006 | 04:23 AM
lightshow's Avatar
i think the belt just might be loose
NemoDat
May 31, 2015 01:25 PM
WILLYS60
Jun 24, 2013 02:25 AM
joehelf
Dec 14, 2011 08:54 PM
thunder_x
Apr 11, 2007 10:52 PM
maro
Mar 9, 2007 03:46 PM
