Cigarette Lighter Out !
Old May 7, 2013 | 08:12 PM
TiffanyH's Avatar
Question Cigarette Lighter Out !
I just got a 2009 Honda Accord LS or LX (I don't remember right now) about 2 months ago, and my cigarette lighters went out! What does this mean? I checked the diagram of the fuse box online and I don't see a fuse for cigarette lighters! I went to Auto Zone and they said they don't carry them! I don't even know where the fuse box is, to look at it! Please if someone could help me I would greatly appreciate it!
Old May 7, 2013 | 08:20 PM
In 2003-2007 shop manual, fuse for "front accessory power socket" is No. 9 in under dash fuse box. No 32 fuse in underhood fuse box drives the accessory power socket relay and if out would also disable socket. Check both of these.
Owner's manual should show location of under dash fuse box.
Old May 8, 2013 | 02:23 PM
T/H Is Really on the BALL, isn't he..Yeah he is..Yeah You are!
Great info for her..maybe she will bake you a pie if she bakes .
Angelo
Old May 8, 2013 | 06:24 PM
Four or six cyl car? Have you tried a different charger in both sockets to be sure it isn't the charger that is having the issue?
I only ask as because after looking at the wire diagram for the '08-'10 4 cyl (hence my first question) the only "common" thing between the two sockets is #18 drivers underdash fuse....but if that was out other things would be out....audio, center info display, ect......
BTW, #18 fuse, once you find the box, is the "top center" fuse.
Old May 8, 2013 | 06:39 PM
One more thought....could you have blown two fuses?
In the drivers side fuse box, #23 15amp is for the front socket. In the Left row of fuses, it is the 5th one from the bottom - pull it and check. If that one is blown I can tell you which fuse in the pass side fuse box is for the rear socket.
Again, using a 4 cyl wire diagram here.
EDIT: I'd post the diagram and pic's but there is something about copyright laws that has me worried
Old May 9, 2013 | 10:57 AM
TiffanyH's Avatar
Thank you Texas Honda... The only thing is I have a 2009 so I don't think that info for the fuses applies to my car. WheelBrokerAng actually I do bake lol!
Old May 9, 2013 | 11:03 AM
TiffanyH's Avatar
Poorman212... I believe its a six cyl... thanx for all the info! Umm being that neither you nor Texas Honda are in NY lol I will take it to a mechanic to look at it!! But I greatly appreciate everyone's input!
Old May 9, 2013 | 05:02 PM
Check the fuses I referenced, I can't believe the wire diagram/fuse panel layout are that different between the 4 and 6.....the engine yes but the wiring inside the car.....no.
yankeeryu
Aug 24, 2007 04:09 PM
coolgmslife
Jul 5, 2007 10:36 PM
junbei
Apr 13, 2006 01:37 PM
latoilette
Jan 9, 2006 03:48 AM
msmiz
Jan 5, 2006 12:28 PM
