Multiple misfires, rough idle, after doing a bunch of work
Old Mar 17, 2018 | 08:39 PM
conkermrd's Avatar
Default Multiple misfires, rough idle, after doing a bunch of work
So today I took my upper intake off to clean egr port, also changed spark plugs, adjusted valves, cleaned IAC, cleaned everything I could, replaced gaskets. After all said and done, start it up after a little bit of cranking and has rough idle. Then cel came on with misfire on 4, 5 and 6. Any thoughts? Or good troubleshooting tips or where to start?
Everything worked fine before I did all that. The main reason for doing it was cel was on for egr insufficient flow.
Old Mar 17, 2018 | 08:49 PM
conkermrd's Avatar
Also it's a 2000 EX V6
Old Mar 18, 2018 | 11:45 AM
Check idle Long Term Fuel Trim and Short Term Fuel Trim w/ OBD2 scanner. If high LTFT & STFT (> +20% combined) look for a intake air leak on front cylinder head intake. A reduction from idle values of LTFT & STFT at higher rpm (2000-3000) also suggests intake air leak.
Nalnin
Jun 28, 2015 08:16 PM
RedChops
Apr 16, 2013 04:30 PM
KaboomCult
Jul 7, 2012 10:58 AM
hess1809
Mar 1, 2011 12:10 AM
98Accord220HP
Jul 3, 2006 11:23 PM
