[Deleted]
Old Apr 5, 2007 | 03:47 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Apr 5, 2007 | 03:52 PM
sir_nasty's Avatar
Default RE: electro turbos ne good?
Since this is a valid post I will allow it for the time being. However, as was requested please change your username to something more appropriate before making any more posts.
Old Apr 5, 2007 | 06:16 PM
Shadow1992's Avatar
Like every performance mod, an electric turbo/supercharger has it's place and application. There are many N/A mods that'll boost airflow into and out of an engine, and give you more performance, but they all work on the fact that atmospheric pressure is pushing air into your engine. The turbo's and super's pull air in and force it into the engine. Now even a mild turbo or super does around 5-8psi, but can cost anywhere from $1500 to $3500. The electric may only cost $500, but only gives 1-2psi of boost. Not a lot, but better than nothing. Enough for say 10%more power. IF you are not going the expensive mod route, than it could be worth it, as it requires minimal changes to the engine, nothing more than attaching the turbine to the end of your intake.
Old Apr 5, 2007 | 06:53 PM
03Sleeper's Avatar
Electric Supercharger Turbo Hybrid. (ESTH)
http://www.halfbakery.com/idea/Elect...Turbo_20Hybrid
Sounds awesome...but how much money would that cost??
EDIT- Or wait for Honda to release their secret weapon: http://www.electrifyingtimes.com/honda_dualnote.html
Old Apr 5, 2007 | 08:35 PM
marbro's Avatar
There are only a select few electric superchargers that work as they claim, but in the end people go and use the pos 20 dollar ones which dont help with anything
Old Apr 5, 2007 | 10:56 PM
theBrewMeister's Avatar
I'd really like to hear from someone who has tried one of these eRam electric supercharger deals. They claim you can stack em -two in-line, to produce a higher psi rating.What I wouldconsider is the NA psi rating on a stock set up. I think i read somewhere that my f22b2 will move somewhere around 435 cfm (at what rpmI'm not sure- help me out here if you know this).So, in order to create any sort of "boost" you would needa "unit" tohave the ability to move much more than this.
A simple boat exhaust fan cannot acomplish this task.But, the pictures shown of this eRam device show a much larger impeller than that of a normalboat fan that they sell on ebay. So I am led to believe that it may be possible to produce some boost- if it can move enough air consistently. <p>
<p>heres a link to what they say it will do for my car...<p>http://www.electricsupercharger.com/...t-selector.cgi
Old Apr 5, 2007 | 11:41 PM
Shadow1992's Avatar
One unit gives about 1psi, two of course about 2psi. CFM isn't a measure of boost or pressure. IT's the amount of air that can move through in a given time, cubic feet per minute CFM. N/A regardless of the CFM, is always 14.7 lbs of pressure, anything above that is boost. So eram with 2 psi of boost gives total pressure of 16.7 (14.7 + 2)
Deleted User
May 11, 2006 02:08 AM
Deleted User
Nov 15, 2005 06:26 PM
Deleted User
May 9, 2005 02:16 AM
Deleted User
May 4, 2005 06:13 PM
Deleted User
Mar 23, 2005 01:48 PM
