How to get a F22 to 300HP!
Old Mar 7, 2008 | 01:46 PM
  #21
Default RE: How to get a F22 to 300HP!
ORIGINAL: marbro
yeeeeah, doing a resleeve is usually 1k+ depending on shop..... most the places around me quote 1500
Mahle has new pistons out with a special coating on the skirt so you can have forged pistons without having to sleeve the block
Old Mar 7, 2008 | 03:24 PM
  #22
accrd94ex's Avatar
i would rather get it sleeved then those pistons man. And a 500 dollar H22A is not a good idea it doesn't have anything it needs i will bet on it. Or if it has everything nothing works correctly so there for you got to replace it all anyhow stay with the F22 get a turbo off an eclipse or get the Turbonetics kit it will work fine but search the forum this question has been asked alot since i have been here and that hasn't been too long.
Old Mar 8, 2008 | 12:37 AM
  #23
nrmskate's Avatar
Trust me, I know what I need to do if a go with the H22 and what I need for the F22.
Im just not the money type of man, I have been saving for a while.
I think I might turbo the F22.
Old Mar 11, 2008 | 04:21 PM
  #24
RIPsr20
i agree, nitrous is for suckers and is the lazy way to get power. nitrous runs out, while boost and n/a power goes forever. i believe you can get your f22 to 300hp naturally asperated, but you definately dont have the money for that. go turbo.
Old Mar 11, 2008 | 06:53 PM
  #25
accrd94ex's Avatar
ORIGINAL: nrmskate
OK buddy if you know what you need to know then delete your thread you started. If you knew all you needed to know why make a thread in the first place please do explain guy. Don't say you know everything because trust me you don't i can tell because you made this thread. Another reason i can tell is because you said
H22:
Swap + engine = possibly 500-900$
Turbo kit = 1500$
Rebuild engine sleeves and head = idk 100-300$
Whereas the F22:
Turbo kit = 1500$
Already has good compression ratios and does not need rebuilt.
I mean to me, it would be senseless to do the H22 one.
But I see that my f22 Turbo would be the same as a stock H22.
idk, its all so confusing....
So please guy don't say that you know all this SH*T when you don't you came here asking for advice we give it and you then say you know everything you need to know after we tell you please just be civil and be thankful for the advice we give.
Old Mar 11, 2008 | 08:11 PM
  #26
marbro's Avatar
ORIGINAL: RIPsr20
f22..... 300hp... n/a? ummmmmm not so much.... if you did that you wouldnt be able to run it on the street..... and the only one ive seen stats on thats come close to 300hp was an h22 97mm stroke 100mm bore with 11:1 compression and was in a prelude body
Old Mar 11, 2008 | 08:52 PM
  #27
RIPsr20
ORIGINAL: marbro
ORIGINAL: RIPsr20
excuse me, i wasnt as clear as i should have been.
Old Mar 11, 2008 | 11:57 PM
  #28
nrmskate's Avatar
@ accord94ex
Settle down bro.
Im not stating I know everything I need to get 300HP off EITHER of the engines.
Im stating Im gaining more knowledge that YOU guys have given me, and starting to understand on reaching my goal.
Im not a fighter man, I love people.
In no way do I like to argue with people so always take me as a positive person, I appreciate everyones help, no doubt.
Old Mar 12, 2008 | 07:48 AM
  #29
BlkCurrantKord's Avatar
F22a1, 17:1 compression, fully built...
Puts out over 300hp. Drag motor only.
One of the guys on 6GA is currently working on 250whp with a F22a1 into his 6thgen.
Old Mar 13, 2008 | 08:50 PM
  #30
HORSEPOWERJUNKIE2007's Avatar
anything is possible when you have money and knowledge.
