2005 Accord lx wiper issues
I am havig issues with my wipers not turning on. I replaced the wiper motor, switch, checked fuses, tried under hood fuse box from junkyard. I am getting power to the motor, tried grouning the motor with a jumper wire and changing out the new motor and switch with second new ones but nothing. The washer pump works fine. There is a click in the under dash fuse box when turning the wipers to any position but thats it. Any ideas? Thanks in advance!
2005 Honda Accord LX 2.4 AT
The 05 accord has body error codes that get stored and can indicate problem. They start with the letter B and have four numbers, like B1234 that are specific to Honda. You may want to stop by an autoparts and have them read codes. Their scanner may be able to read the body codes. It is free and worth a shot.
The wiring diagram is kind of confusing. The shop manual has some tests you can do at the wiper switch at the steering column. With the switch plugged in, you will have to back-probe the connector to measure voltage. Use a good ground for you volt meter.
Blk wire should have less than 1 volt.
Wht/red wire should have 12V all the time.
Yel wire should have 12V with the key in the II position.
I'll take a closer look at the shop manual to give you some other suggestions.
Do you kmow if the relays above the under dash fuse box are related to the wipers?
There are other wires that go to the wiper. Can you test the voltage on each and post back? Test for voltage with the wiper switch set to low and high. I'm not in front of my normal computer, so I can't look up the wiring in the shop manual.
I had the car checked for codes with a friends reader and at Advance Auto and neither one had any "B" codes. There was only an emmisions code. I tested the volts to the motor plug in all postions and only had 12.3 v on the green wire and 11.15 v on the white wire each time. I did another continuity test with the key switch on this time and in the high position on the yellow wire was showing .01 resistance. The blue wire on low read .01 resistance. Any other thoughts?
The yellow wire should have 12V to ground when the key is in the II position. Just want to verify you tried testing for voltage with the key in the II (normal run position).
The yellow wire runs from the under hood fuse box to the wiper motor. The connector for the under hood fuse box has a max of 5 wires and is U-shaped. The yellow wire is at the bottom of the U. Check continuity (resistance) between the yellow wire on the wiper motor and the connector to the fuse box.
Also, check the #21 fuse (7.5 amp) in the fuse box under your dash. See the pic below for the fuse location.
Edit: wiper arms are set to the correct position and everything is back to normal. I would not recommend reman wiper motors from Advance Auto Parts. Autozone and O'rileys get theirs drom the same manufacture. It'll be NAPA for me from now on.
Jcaleno
12-08-2011 02:16 AM
