South West AZ, TX, NM, OK
Install of Amplifier - Need Help
Old Feb 23, 2010 | 05:14 PM
nightowlll2010's Avatar
Default Install of Amplifier - Need Help
I'm installing an power inverter and an audio amplifier in my 07 accord. For FYI it's a V6 ExL Navi 4 Dr. - I was wondering if anyone knows the best place and/or route to run the power cable from the battery to the cabin? Any help would be much appreciated.
Oscar
Texas
Old Feb 24, 2010 | 01:17 PM
keep_hope_alive's Avatar
there should be some spare grommets on the driver's side that you can get through.
get under the driver's dash (remove lower dash trim), pull back the factory firewall sound barrier (don't tear it as you want to put it back), and look for grommets or flat circular areas then verify on the engine compartment side that you are free and clear. Typically, above the gas pedal. Make sure you use a proper, watertight grommet - Streetwires has a nice one.
You can also squeeze some 8awg in through the factory wire grommet on the upper driver's side - it enters just below the windshield (IIRC).
what size power wire?
Old Aug 16, 2012 | 09:46 AM
grommets that are already there.
Tuner Jr.
Aug 7, 2013 07:35 PM
calebcrawdad
Jul 30, 2013 10:13 PM
1sarge
Dec 19, 2011 02:23 PM
Green_Accord
Mar 15, 2006 08:03 PM
SpeedyV6
Jun 8, 2005 12:38 PM
