1.5" drop all the way around NEED SUGGESTIONS!
Old May 30, 2010 | 04:19 PM
vengeance's Avatar
Default 1.5" drop all the way around NEED SUGGESTIONS!
ok i have a 98 and im gonna drop it 1.5" this is what i have in mind for ordering. What would i need with: KYB GR-2 struts all the way around and the Eibach Pro Kit 1.5" front and back
need suggestions!
Old May 30, 2010 | 05:08 PM
g22cd5's Avatar
Supper Moderator
The gr2s are OEM replacement ONLY....so nothing will work to drop them. They will blow within a week. Not a good idea to put any type of drop on them.
Eibach Pro Kit is good you just need good struts...koni makes some of the best you can buy.
Old May 31, 2010 | 12:35 AM
vengeance's Avatar
thats exactly what i was needing to know because i wasnt forsure on the struts. also would i need anything for alignment or anything of that nature?
Old May 31, 2010 | 06:24 AM
g22cd5's Avatar
Supper Moderator
yes alignment is a must
Old Jun 1, 2010 | 08:13 PM
vengeance's Avatar
sry i worded that question wrong. i meant to say a camber kit or anything of that effect or is it evn a derastic enough drop for one?
Old Jun 1, 2010 | 09:12 PM
g22cd5's Avatar
Supper Moderator
Well with any type of drop you will mistily need a camber kit. I have a camber kit but I’m running ALOT of negative camber so I can take turns ALOT faster than most but wears down your tires ALOT faster I mean ALOT faster. I’m also sitting really really low...less than a finger gap all the way around. That’s ALOT more than just 1.5" drop.
Basically look at thies pics and you will see what your tires will look like if your lower your car w/o a camber kit. Even know this is the outer edge of my tires that are wearing due to having negative camber this is what you inner edges of your tire will look like without a camber kit.
so put it this way positive camber (what you get when lowering your car with no camber kit) makes your tires sit like more like this /-----\ vs. negative camber makes your tires sit more like mine \-----/
That is only after 8-10k miles maybe less. I really don’t remember...but they don’t last long at all.
Old Apr 15, 2011 | 10:40 AM
BlakKarsilverRims's Avatar
Default Camber COrrection
You get Negative Camber from lowering you car, not positive
Negative Camber /-----\
Positive Camber \------/
jtimc7
Jun 13, 2013 11:57 AM
joenintiesc
Apr 14, 2013 07:29 AM
ysbarney
Oct 1, 2012 06:04 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
