1997 Accord Upper Ball Joint Loose - Needs Replacement
Old Jun 13, 2011 | 01:07 PM
tlhfirelion's Avatar
Default 1997 Accord Upper Ball Joint Loose - Needs Replacement
I'm a bit confused at how to fix this. Is this a bolt on item or does it need to be pressed on/off? If pressed I'll have my mechanic do it. If not I'd like to give it a go but am not sure how to do so.
Any help is appreciated.
Vehicle Info - 1997 Accord SE 4 Cylinder Automatic 4 door. 217,000 miles.
Old Jun 13, 2011 | 01:19 PM
Is the process the same for a 97 that it is for this 95? If it's even close to that easy I can do that no problem.
YouTube - ‪Tutorial: How to Install an upper ball joint on a 1995 Honda Accord‬‏
Old Jun 13, 2011 | 02:46 PM
Tek310's Avatar
yes 94-97 are the same.
it is recommended you replace the full upper control arm when you need to replace the balljoint.
if you choose to put a new ball joint, get it tack welded on the top to keep it secure.
sgull
Aug 24, 2013 03:35 PM
gbphilg
Aug 24, 2010 08:29 AM
stonie1
Aug 18, 2010 06:48 PM
Eddietee20
Jun 10, 2009 05:00 PM
Hoang_Nguyen
May 13, 2007 10:13 AM
