2000 accord lx
Old Nov 12, 2013 | 07:22 PM
ruggeri5054's Avatar
Default 2000 accord lx
Hey guys.. need some tips here.. my 2000 accord lx had some bad thumping over bumps about 6 months ago.. so I determined that the pass. strut was the culprit. which it was. .. Now I noticed it again.. only it seems to be coming from the rear.. so I started pushing down on the trunk and it is really loud back there.. All bushings check ok, the struts are almost new.. and nothing really seems lose. Any Ideas? I dont want to replace the struts if I do not have to.. my gut tells me to look else where beyond the struts
Old Nov 13, 2013 | 08:13 AM
Anti-sway bar links/bushings are a common problem on many suspensions and are easy to repair.
Old Nov 16, 2013 | 07:55 AM
yep, only problem is, they are 100% fine. Acutally they look pretty new, but have zero play, have zero wear.. I know it is hard without seeing it, and something has to be wrong, but I can not find it.
Old Nov 16, 2013 | 12:03 PM
If you can produce noise by pressing down on suspension, you may have a loose strut mount; something not tight or missing in the stack-up of parts.
DIY?
Old Nov 17, 2013 | 10:00 AM
DeanSweet's Avatar
Check the top nut on strut. I had a neighbor with exactly what you are describing and come to find out he used hand tools to tighten down this nut and it doesn't really work that well unless you have somebody with a locking wrench or whatever holding the strut rod.
I used a my air impact and it spun maybe 2-3 rotations and voila, clunking gone.
rtrainer
May 10, 2013 05:36 AM
mike.stribling
Jul 14, 2010 01:08 AM
StatzFinest
Feb 10, 2008 11:32 AM
