98 lx questions on what would cause..
Old Mar 6, 2007 | 07:15 PM
whitehonda
Default 98 lx questions on what would cause..
my car to shake at about 50. its completly stock. i was forced into a ditch and was able to drive out. i had it looked at they said its either the inner tie rods or the bushings. suggestions please.
Old Mar 6, 2007 | 08:36 PM
sir_nasty's Avatar
Default RE: 98 lx questions on what would cause..
first thing I would check is that your lug nuts are tight, second, jack up the front of the car and grab the tire and push/pull on the top/bottom of it and see if it wiggles/wobbles a lot back and forth, if it does then look underneath/behind while you do it and see if anything in there is moving, if it's not then most likely it's the bearings or something of that sort... try to narrow down which side you're working on/with, also it could be a bent rim or lost wheel weights, see if that shop would check your tires for balance/bent rim....
Old Mar 6, 2007 | 08:56 PM
And of course there's always the broken belts in the tires..I just replaced two fron tires this week myself...
TireBrokerAng
GreenGeckoUSA
May 31, 2023 05:00 AM
Uberpippi
Mar 23, 2015 05:32 PM
thesoymilk
May 27, 2013 12:39 PM
c.schoch
May 18, 2010 11:39 AM
blazedg
Jul 5, 2005 07:52 PM
