Help me eliminate my horrible fender gap!
Old Mar 31, 2013 | 11:24 PM
ATXAccord's Avatar
Default Help me eliminate my horrible fender gap!
Ok so some of you may have seen my introduction post, I recently purchased a 94' Accord Lx and its sitting on a set of 18 inch Enkei rims with new 205/40/18 tires I believe. The new rims look awesome, but the at least 2 inch fender gap IS KILLING ME! I hear function form coilovers are the way to go as far as bang for your buck is concerned and I'm pretty sure that's the way I'm going to go but I have one concern.
What I'm assuming is a strut bar is sitting maybe .5 to .75 inches away from my tire thread. If I drop my car won't it rub? The suspension on my previous car wasn't setup this way so I just don't know how it'll work out. Call me a noob if you want, I'll accept it haha
also I was wondering about these Ground Control Coilover Conversion kits for 350 bucks? Is it even worth looking into? Ground Control - Coilover Conversion kit, 90-97 Honda Accord
Old Mar 31, 2013 | 11:54 PM
hondafreak91c's Avatar
You'll have no problem rubbing on the upper control arm.....it moves up when the suspension compresses.
Function&Form is one of the cheaper setups. Their quality is decent, but nothing top notch. The ride is pretty firm, since the spring rates are pretty high. They aren't for everyone. You can find them for about $600 shipped.
Ground Control is an awesome company. They make high quality coilovers, and back their products with a lifetime warranty. It is only the coilover sleeve, so you will need to pair it with some shocks. I wouldn't run your stock shocks.....they will blow shortly after lowering. The best shocks to pair with the GCs are Koni Sports (Yellows). They are made for lowered cars. They have a lifetime warranty. The ride is definitely the best I've experienced in a 5th Gen Accord.
If you know where to look, you can find the Koni/GC setup for less than $800. I will shortly be purchasing this setup because for the lifetime warranty, and ride quality, its the best setup (imo).
Old Apr 1, 2013 | 08:12 PM
ATXAccord's Avatar
thank you so much this is exactly what I needed to know! let me know how that setup works out for you
Old Apr 19, 2013 | 03:44 AM
Just thought I'd update you......
I've had my Koni/GCs installed on my car for almost 2 weeks now. And I have nothing bad to say. I have upgraded spring rates (550 front, 450 rear). I wanted something stiffer than the standard OTS (off the shelf) spring rates. Even with these spring rates, the ride is still VERY comfortable...especially on the highway.
Old Apr 20, 2013 | 11:01 AM
ATXAccord's Avatar
Sounds like its a good setup after all,. Do you have before and after pics of the drop?
Old Apr 21, 2013 | 12:41 AM
Here is a before picture on my Eibach springs.....
And here is now. The car is an inch lower than before.
Old May 2, 2013 | 09:23 AM
wrencredle's Avatar
hey honda freak what set up were you using with the eibach springs, and are those the sportlines?
Old May 2, 2013 | 04:58 PM
I was using Eibach Sportlines and KYB-GR2s. I would recommend something other than the GR2s.. They are not meant to handle a drop, since they are OEM replacement shocks.
I'd recommend Koni Yellows or Oranges, Tokico Illuminas, or KYB AGX.
RA041324
Oct 18, 2023 11:59 PM
Viets90
Aug 19, 2013 11:48 AM
tiredredcoupe
Dec 18, 2009 11:45 AM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
LaminatedKitten
Jan 15, 2007 01:19 AM
