How low can i go ???
Old Jul 27, 2007 | 10:02 AM
ohsmustangs09's Avatar
Default How low can i go ???
I want to lower my accord, but i dont know how low i can lower it w/o having to replace my shocks...i have about 2.5" of fender gap and i would like to git ride of as most of that as i can....any info greatly appreciated, thanks!
Old Jul 27, 2007 | 11:36 AM
smaglik's Avatar
Default RE: How low can i go ???
1" is about all you can do without replacin the shocks...though they will still likely wear faster.
Old Jul 27, 2007 | 11:45 AM
finch13's Avatar
Yes, Eibach Pro-Kit was designed to be used with the stock shocks and will get rid of some, not all of the gap. IMO it looks the best since there is equal gap on the sides and top of the tire. Depending on how old your shocks are the ride will get bouncier, but will hold better in the corners. About $190 at tirerack.com, that's where I got them from and I looked at about 20 different sites and that was the cheapest.
Old Aug 1, 2007 | 08:57 AM
alright thanks i will look into the eibach pro-kit...yea i live 5 minutes down the rode from Summit and they are 260 there...ha...tirerack it is, thanks!
oh yea, what about a wheel alignment kit ? would i need anything like that ?
Old Aug 4, 2007 | 03:02 PM
finch13's Avatar
I put my springs on a brought it in for a full alignment. They adjusted everything back to stock except the rear camber which is not adjustable without a camber kit. The camber is not severe enough to cause tire wear concern so you can go without it.
Old Aug 15, 2007 | 01:11 AM
Super Eurobeat's Avatar
the amount of lowering you can get the car (safely) to do depends on many variables.
When you lower a car, all the geometry of the suspension changes, control arms come up and closer to parallel where the point of understeer becomes excessive, the amount the damper (shock absorber/strut cartridge) can be pushed before it bottoms out. For slamming the car you will need short bodies shocks to increase suspension travel, along with adjustable coilovers (like ground control) to stiffen the car up so it doesnt bottom out. If you have tire to fender clearance as little as my car then you will need to stiffen it up a lot and reinforce mounting points.
You will need to use spacers to put control arms back to their original angles if you decide to lower the car over 1.5 inches.
see my fender to tire clearance at static suspension:
Old Aug 16, 2007 | 04:29 AM
steviebix's Avatar
how long do you think ill be able to go b4 i have to switch out my struts?....ive got tein S-tech springs and have had them for about 2000 miles...its a 1.75 inch drop. thanks
[align=left] [/align]
CD7jay
Oct 28, 2009 01:11 AM
ItsNewToMe
May 3, 2009 07:20 AM
Nitin
Apr 20, 2008 07:19 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
thunder_x
Sep 25, 2006 09:34 AM
