Lowering suspension questions.93 Se
Old Jul 10, 2009 | 12:20 AM
pyradell's Avatar
Default Lowering suspension questions.93 Se
1) I have 17's-believe (-40) offset-dont remember- on stock suspension- I bottom out- i understand why and all. I plan on getting coilovers-Question- Will i still bottom out with coilovers or do i have to get stiff lowering springs?
2)I heard there are things that might have to be done under the hood for protection when lowering - something about motor dampeners. Are these an absolute must??
Thats all- just these two questions- Thanks.
Old Jul 10, 2009 | 01:38 AM
Put in the year make model eng tire size and all the other blah, blah , blah stuff-so that we know what your working with..
Old Jul 10, 2009 | 02:43 AM
finch13's Avatar
1) If you're bottoming out on bumps now, your shocks are probably blown. If you get a good set of shocks, the springs shouldn't matter all that much. The more you lower, the stiffer the spring will be, no way around it.
2) Complete bull****. All that needs to be done when lowering is swapping out the shocks and springs and getting a wheel alignment done after, possibly a camber kit in the rear. Your +40mm offset wheels could possibly rub, depending on how low you go.
Old Jul 10, 2009 | 08:22 PM
pyradell's Avatar
Questions answered. Thanks!
DMarley
Jan 5, 2011 10:21 AM
thebigone
Jun 8, 2009 05:02 PM
mak
Apr 19, 2008 10:05 PM
ohsmustangs09
Jun 20, 2007 11:31 AM
