Part install, need a little help
Old May 2, 2008 | 02:05 PM
amc3000's Avatar
Default Part install, need a little help
I tried doing a search and didnt find too much. Wondering if anyone can point me in the right direction. Looking to replace sway bar bushings in my 1992 Honda Accord this weekend. Also, looking to replace outer tie rod ends. Anyone got tips, or a How-To anywhere? Thanks
Old May 2, 2008 | 02:08 PM
finch13's Avatar
Default RE: Part install, need a little help
Sway bushings? The rubber inside the U shaped mounts? Remove the sway bar end links and then remove the 4 bolts holding the 2 U mounts on. Replace rubber then reverse itall.
Old May 2, 2008 | 02:09 PM
finch13's Avatar
There's a good possibility you will shear those bolts so douse them in penetrating oil first.
Old May 2, 2008 | 02:19 PM
amc3000's Avatar
well, i guess its the other end. The end closer to the wheel. The one with like one bolt and 4 rubber bushings. I guess the end links.
Old May 2, 2008 | 02:23 PM
finch13's Avatar
Yeah, they're technically called stabilizer end links. Way easier to do, just hold the bolt with a wrench and ratchet away at the nut. The washers should have thedomed endsfacing each other and the bushing have metal in the middle of each pair.
Old May 2, 2008 | 02:25 PM
amc3000's Avatar
Old May 2, 2008 | 02:27 PM
finch13's Avatar
That's the one. Mine had washers with a domed side on them...
Old May 2, 2008 | 02:40 PM
amc3000's Avatar
awesome. thanks so much for your help!!! Im going to do this , this weekend. thanks again. You are a big help!!
delkampg
Apr 13, 2008 08:24 PM
GregAU
Mar 4, 2008 12:46 PM
1BADSS
Sep 12, 2006 05:18 AM
sevenhate
May 31, 2006 01:52 PM
96Cord
Sep 29, 2005 03:34 PM
