Steering wheel shakes when braking.
Old Jun 2, 2009 | 02:44 PM
Jcaleno's Avatar
Default Steering wheel shakes when braking.
When i reduce the speed specially if i'm already stopping the steering wheels shakes, I almost feel like the tires r too, but don't know. anyone had this before?
Old Jun 2, 2009 | 03:22 PM
"Warped" rotors, especially if it ONLY does it while braking.
Old Jun 2, 2009 | 04:50 PM
00AccordLX5spd's Avatar
Registered User
x2 for "warped" rotors.
Wheels may need to be balanced as well. Not expensive
Old Jun 3, 2009 | 10:40 PM
Jcaleno's Avatar
Default ?
Whats a warped rotor? does it need replacing?
Old Jun 4, 2009 | 07:05 AM
Usually a "warped" rotor is really just uneven friction properties around the surface. It's usually caused by braking hard & coming to a stop, then holding the brakes clamped hard on a very hot rotor. Unfortunately you can't avoid doing that in some traffic.
Usually can be fixed by resurfacing the rotors, occasionally you can fix it by doing a "bedding-in" procedure. Like this...
Find someplace you can do this without being stupid in traffic.
Brake hard from 40 to 10. DO NOT COMPLETELY STOP.
Drive a couple minutes to cool them off.
Repeat 4 or 5 times.
Brake REAL REAL HARD from 50 or 60 to 10. DO NOT COMPLETELY STOP.
Drive around 8 or 10 minutes to cool them off.
Repeat about 8 times.
You should do this procedure whenever you put on new or resurfaced rotors or pads. After you do this, they seem to tolerate clamping on a hot brake better.
stealth94
Sep 20, 2011 04:09 PM
hikjer1
Dec 7, 2010 09:57 AM
hatingmyhonda
Jan 25, 2008 09:39 AM
Aug 22, 2007 01:57 PM
Jul 3, 2005 03:38 AM
