Thump on drives side when a hit bump
Old May 14, 2008 | 04:59 PM
ham00coupe
Default Thump on drives side when a hit bump
Hey guys, I just lowered my 2000 coupe. I rides very nice but when I hit a bump on the road a loud thump occurs> any idea what it could be?
Old May 14, 2008 | 06:21 PM
poff1986's Avatar
Default RE: Thump on drives side when a hit bump
Either you have a loose bolt you forgot, but assuming your knowlegeable you didnt do that, replace your sway bar end links, i had that in the rear on my 02 when i lowered it, replaced the links, noise gone. Good luck!
Old May 14, 2008 | 10:09 PM
vtecHef's Avatar
u sure your wheel isnt scrapin the wheelwell? Cause when i turn hard and if there is any bumps.. my tire is al up on the ww
Old May 15, 2008 | 08:44 PM
clutch811's Avatar
i have a similar problem on mine with the rear passenger. there is a rubber mount that goes in the top part where the coil over spring meets the body. it's like a little rest area that the spring slips into up top. mine is missing(it probably fell out) so check up the top and see if it's there. if not just get a replacement. mine cost like 3.95. however just keep in mind the difference in our cars' years they may be different. also make sure the spring sits back in properly if you need to raise and then lower the car. hope this helps.
Old May 22, 2008 | 04:44 PM
hchanrn's Avatar
did you lower the car yourself? If so did you cut away some of the rubber bumper stop? When I did my car (1998 accord) The instructions stated that I would need to cutt away some of the bumper stop to allow for more travel with the lower stance. If the bump stops where not cut then you may be bottoming out on the stops. I took off a third off the bump stops with 1.5" drop
Punkfarterrrrr
May 24, 2011 03:18 PM
fusionstar
Sep 18, 2009 10:38 AM
quida12
May 5, 2009 06:40 PM
lucky4babs
Apr 9, 2008 12:05 PM
xxxcoojaxxx
Jul 1, 2006 08:49 PM
