Tie rod end help
Old 04-29-2008, 11:57 AM
liam71234's Avatar
Default Tie rod end help
I just finished the rack and pinion and i'm replacing the tie rod ends as well. I am having an issue with the tie rod ends. I can't find a tie rod end that has a long enough threaded end to attach to the knuckle. I got a set from a dealer and a set from checker. The ones from dealer were the closest but they are short by about an 1/8" or a little more. The problem is I can't get the threaded end through the knuckle far enough to get the nut to where i can push the pin through. Do i need to use a special to to knock the tie rod end in farther? or will a mallet do the trick? has anyone had a similiar issue with tie rod ends and think they can help? thank you
jerrym
10-11-2014 05:15 PM
stockxplorer
02-01-2011 12:28 AM
blarf
12-03-2009 12:59 AM
liam71234
04-29-2008 11:57 AM
trukid21
12-05-2007 11:12 AM
Quick Reply: Tie rod end help
