Wheel shakes....
Old Jul 17, 2007 | 11:08 AM
ohiostatepimp22's Avatar
Default Wheel shakes....
I have a 94 accord and when im driving basically around 2000 rpm and 2500 i can feel from the right side of the car a shaking. I have no clue what it is. Im pretty sure i could be a ball joint so i got a ball joint and im going to put that in and see if it takes it away. Anyone else have any other sugesstions
Old Jul 17, 2007 | 11:10 AM
sir_nasty's Avatar
Default RE: Wheel shakes....
The more common 2000-2500 rpm shake is caused by plugged EGR ports, I think it's even called EGR Port Stumble if I remember right Hondadude made a post about it, there is a DIY on cleaning those, if it was a wheel bearing you should feel it at more than one RPM range, speed would be more of a factor than RPM's...
Old Jul 17, 2007 | 11:11 AM
yea i know that but it just seems like in every gear around that rpm it shakes...
Old Jul 17, 2007 | 11:39 AM
smaglik's Avatar
re-read what sir said...its the rpm range.
on another note, do you pimp for the entire state of ohio, or just the columbus campus?
Old Jul 17, 2007 | 04:51 PM
Fenix's Avatar
LMAO @ smaglik
Old Jul 21, 2007 | 05:04 PM
yea i cleaned out these egr ports and wow it is such a big difference
Old Jul 22, 2007 | 10:35 AM
deserthonda's Avatar
have you checked the tires condition ? frt suspension for loosness? does it shake on accell or a constant speed , do you feel it in the steering wheel ?
could also be a possible inner cv joint ,,but we need more info from you ,,,,,,And do not start replacing parts till you have it diagnosed properly ,,
ndp125
Aug 21, 2009 10:32 AM
Jcaleno
Jun 4, 2009 07:05 AM
hatingmyhonda
Jan 25, 2008 09:39 AM
Aug 22, 2007 01:57 PM
Jul 3, 2005 03:38 AM
