why can stock shocks blow out and aftermarket ones not?
Old Oct 30, 2006 | 02:16 AM
thunder_x's Avatar
Default why can stock shocks blow out and aftermarket ones not?
if i lower my car with aftermarket springs and the shocks go out months after, how will i know that the aftermarket shocks i get wont blow out either?
Old Oct 30, 2006 | 03:01 AM
Default RE: why can stock shocks blow out and aftermarket ones not?
You don't know what or when it shall happen...but eventually it's gonna happen..everything wears out as time goes by..
Old Oct 30, 2006 | 03:12 AM
YeuEmMaiMai's Avatar
reason that the stock shocks will fail has to do with height of the springs. shocks are designed to operate in a certain range and when you low the car, you are moving the struts (in the case of an accord) out of this range and it cause the internal valves and seals to fail. After market shocks are designed to work in a wider range or a specific range that was designed into the lowering kit.
Old Oct 30, 2006 | 07:07 PM
thunder_x's Avatar
oo, i see
thanks
Melissa
Aug 25, 2009 12:44 AM
rambleongirl
Aug 10, 2009 04:21 PM
thunder_x
Nov 6, 2006 08:26 PM
thunder_x
May 6, 2006 04:22 AM
