Accord Rims
Old Oct 31, 2013 | 11:09 AM
Dayala's Avatar
Default Accord Rims
I need help!
I put some 18' rims on my 2003 Honda Accord Ex but it looks like they might not work out. Its making a noise and I believe that it might damage the tires.
Who knows what tire size is correct to have on the car?
Old Oct 31, 2013 | 02:47 PM
Hi New Member and Welcome to the HAF...
Try this link which is at the top of this subject thread.
Honda Accord Forum - Honda Accord Enthusiast Forums - Announcements in Forum : Tires & Wheels
Old Nov 1, 2013 | 08:40 AM
18" is only part of the size.
Rim width?
Offset?
Tire size? I think 215/45-R18 is the size.
Old Nov 12, 2013 | 08:31 PM
Dayala's Avatar
How sure are you on the 215/45-R18? I had 225/50-R18 but I took them off because the back ones were making a noise.
Old Nov 13, 2013 | 11:42 AM
Wider and taller BOTH... Did the noise sound like the tire rubbing against the fender??
Tire size came from TireRack's website, but you can try that yourself because I didn't know if you had 2-door or 4-door or what engine. TireRack also takes into consideration what offset the wheel needs. If you have wheels with the wrong offset, then even the correct size tire might rub.
Old Nov 14, 2013 | 03:35 PM
Dayala's Avatar
Yeah it was making a rubbing noise. (2-door and 2.4L engine) How do I figure out the offset is correct or not?
Also the car is all stock and I want to do something to the car but I don't know were to start or what to do to it?? Any suggestions??
Old Nov 15, 2013 | 09:47 PM
TireRack says 18 x 7.5 rims with 45 to 50 mm offset. Lots of 48mm offset in the rims that they list.
So what's the offset of your rims? Frequently the offset is cast into the back side of the rim somewhere, along with the size, with the letters ET.
So you might find "18x7.5 ET48" somewhere on the rim.
And again, 215/45 R18 is the tire size they call for. Your 225/50 tires are both wider and taller, so they may rub anyway even on the "correct" rim.
KevinFelt
Dec 6, 2013 01:14 PM
mlk3
Dec 6, 2008 01:32 PM
Kenyon
Oct 22, 2007 04:15 PM
rydnlow1120
Jul 19, 2007 03:05 PM
markfid
May 9, 2007 11:53 PM
