wheel query
Old Feb 20, 2008 | 11:57 AM
The Big Read
Default wheel query
Im considering buying an 04 accord saloon (euro version).
If I buy it, I want to get some bigger wheels, perhaps 18", cos the arches are too big for the pram wheels it comes with.....trouble is I dont want to compromise the handling.
Has anyone got any advice?
Perhaps you have put bigger wheels on yours and the handling has been affected, or indeed not?
Also while im here, can anyone tell me the offset pls?
And would I need to upgrade my suspension?
Sorry for all the questions, I really wana make sure I get it right.
Thanks.
Old Feb 20, 2008 | 02:24 PM
finch13's Avatar
Default RE: wheel query
1. Assuming that "pram" wheels are the stock steel wheels, the handling will improve depending on the tires. Less sidewall flex and more rigitity means quicker steering response becase there is smaller amount of soft (tire) between two hard surfaces (wheel and pavement). I went from steel 14" to alloy 17" and handling was much improved, albeit the ride became rougher since there is less rubber to absorb bumps in the road.
2. Generally the offset runs anywhere between +35mm and +45mm. Mine are +42mm.
3. You don't not necessarily need to upgrade the suspension, but heavier wheels meansaccelerated wear and tear on dampers and such. Nothing to worry about too much.
Old Feb 21, 2008 | 11:00 AM
The Big Read
Thanks mate
Old Feb 21, 2008 | 01:19 PM
falkore24's Avatar
In the tire section stickies are links to calculators that will sow you the effects of changing tire sizes and rim sizes, widths and offsets. Look at the stickies in the suspension section to learn about that ..... esp. Suspension 2.0
kgjhome
Aug 2, 2011 10:06 PM
darkgreen18290
Sep 28, 2010 12:47 AM
Guis7
Jul 13, 2009 07:53 AM
yiannix
Nov 9, 2008 03:56 PM
taffia
Sep 5, 2007 02:54 PM
