"Wheel Weight Lip" VS "No Wheel Weight Lip"
Old Jun 5, 2012 | 06:40 PM
Reggi's-accord's Avatar
Default "Wheel Weight Lip" VS "No Wheel Weight Lip"
Hello, I'm shopping for a replacement original equipment wheel for my wife's '07 SE. I keep seeing reference to a "Wheel Weight Lip" and "No Wheel Weight Lip". Go easy on me... is there a easy way to determine what type she has now? Is there a lip dimension I can take to know for sure? (And No, there are no weights on the outside now...)
Thanks,
Bob
I also just posted a WTB in this forum's WTB area. I thought that I'd try that before I try to find a good deal online.
Old Jun 6, 2012 | 11:48 AM
That refers to the shape of the outer lip of the rim. It doesn't affect the fitting of tires, but it DOES affect what kind of balance-weights can be used.
Clip-on weights (similar to what you'd use on a steel wheel) need a thinner lip, and some room to clip them on. If you get a "no-lip" wheel then you have to use glue-on weights. At least on the outboard lip of the wheel. With modern wheel-balancing equipment, shops should be able to use whichever kind of weight is required for the wheel.
Here's an example where there's no lip for clip-on weights. Compare against the inboard rim; pretty much all wheels can take clip-on weight on the inboard rim.
Old Jun 6, 2012 | 07:17 PM
Thanks Jim!
joenintiesc
Apr 14, 2013 07:29 AM
HondaAficionado
Nov 30, 2010 05:24 PM
scottisart
Nov 1, 2009 11:25 PM
asphyxxed
Feb 13, 2007 01:25 AM
kidwidstyle
Aug 2, 2006 04:59 AM
