F23A1 in a 1992 Accord EX?
Old 12-14-2007, 12:03 PM
mattv
Default F23A1 in a 1992 Accord EX?
Hello Everyone
I have a chance to pick up an F23A1 motor for $200
F23A1 honda accord motor, running when pulled. 60-70k miles on it, includes complete longblock with dizzy, intake manifold and flywheel..
My 1992 accord EX (Auto) has a rod tick and either needs to be rebuilt or replaced. What are your thoughts on swapping in the F23A1? I'll probably need to get a harness and maybe an ECU (not sure what comes with the motor) but I'm wondering if it fits and if it's worth doing?
Thanks much!!
Old 12-14-2007, 12:15 PM
finch13's Avatar
Default RE: F23A1 in a 1992 Accord EX?
Even if it doesn't fit it might be worth to buy and fix up and resell it for a higher price... The F23A1 is 6th gen engine you want to put into a 4th gen...
Old 12-14-2007, 01:10 PM
BlkCurrantKord's Avatar
It should fit almost perfectly. You may run into some problems with the driver's side mount though. You'll obviously have to extend and rewire a few things. The biggest will be adapting the IACV on the back of the F23 intake plenum to your car. The F23 uses a 3 wire, yours is a 2 wire. There's obviously going to more things to work out but it shouldn't be that hard of a swap.
turner433
09-28-2010 11:19 PM
zeroice
01-15-2010 11:39 AM
kris.h1987
07-02-2009 03:02 PM
finch13
02-26-2009 12:26 AM
VTEC!MASTER
08-28-2008 11:24 AM
Quick Reply: F23A1 in a 1992 Accord EX?
