Sponsored by:
Sponsored by:
98 Accord Brake light problem
Old 05-19-2009, 09:03 PM
Pbbd7092
Default 98 Accord Brake light problem
Long story short back lights light up when lights are on but all three brake lights (Left,Right, and the light over the back seat) do not work when brakes are pumped/pressed in.
Brake light switch?
Checked all the fuses,unhooked the battery and cant think of anything else
I did just have the pads replaced but the lights worked for a week after that until now so I don't think it could be that but I could be wrong
any info/ideas would be so helpful
thanks guys
Old 05-19-2009, 10:12 PM
hondadude's Avatar
brake light switch would be the next logical thing to check....watch the switch plunger action as well
Old 05-20-2009, 10:02 AM
deserthonda's Avatar
at the brake switch, jump 2 wires together wht/yellow and wht/black , if brake lites work switch is bad , also did you chk the fuses ??? under hood # 47 20 amps,, under dash fuse # 9 7.5 amps
Old 05-20-2009, 09:38 PM
Pbbd7092
ok so my dad busted out this "tester" ...had a red wire and a black wire to a light bulb...so i got under the dash and unplugged the switch from the wires.
The wires from the car to the switch have a plastic housing to just plug into the switch but the copper plugs on the inside are exposed...
i followed the white/yllw and blk/wht wires to their plug and tired to attatch the red prong on the "tester" to the ylw/wht and black prong to the blk/wht,when it didnt work i switched the prongs to the opposite wire and no results
is this an in effective way of testing or is it not the switch?
Old 05-21-2009, 07:11 AM
Originally Posted by deserthonda
... also did you chk the fuses ??? under hood # 47 20 amps,, under dash fuse # 9 7.5 amps
Fuses??
Old 05-21-2009, 01:30 PM
Pbbd7092
Brake light switch?
thanks guys
did that.
Old 05-21-2009, 02:12 PM
did that.
oops, I missed that...
Old 07-13-2009, 09:14 PM
palmbeach40
Hello,
In my Car Control panel BRAKE light always Red and ON.
Any suggestion ?
HONDA - ACCORD LX- 2000 - 99K Miles
Old 07-13-2009, 09:29 PM
You should probably start a new thread. Your problem is likely different from the original poster's and other people will be confused when reading.
WindPhoenix
08-10-2012 10:15 PM
DannyJdm
03-28-2012 08:03 AM
victorywhity
03-24-2011 09:37 PM
98accord98
09-08-2006 01:25 AM
Quick Reply: 98 Accord Brake light problem
