help with horn not working
my 1995 honda accord lx ok so my horn stopped working idk how to figure out issue i used a jump pack and tested horns and they do work. so when i press horn button i hear a click not sure where its coming from but i hear it click the button i think. so horn doesn't work where should i check and how do i check? thank you in advance
I've moved this to General Tech for better views.
Can you help us out and at least tell us what year car you have
Was there anything that lead up tp this.....just did X or Y and it stopped working
You can check the power supply to the horn by pressing on the horn and check for voltage with either a test light or a multi meter. If there is voltage then the ground is bad. I will try and check the shop manual this morning for further diagnostics on the switch, relay etc.
fireblast713
11-01-2010 02:06 AM
Rob_KCMO
04-18-2010 12:05 AM
