help with horn not working
Old Sep 28, 2015 | 03:18 PM
stenny's Avatar
Default help with horn not working
my 1995 honda accord lx ok so my horn stopped working idk how to figure out issue i used a jump pack and tested horns and they do work. so when i press horn button i hear a click not sure where its coming from but i hear it click the button i think. so horn doesn't work where should i check and how do i check? thank you in advance
Old Sep 28, 2015 | 05:40 PM
I've moved this to General Tech for better views.
Can you help us out and at least tell us what year car you have
Was there anything that lead up tp this.....just did X or Y and it stopped working
Old Sep 28, 2015 | 06:25 PM
stenny's Avatar
sorry its a 95 honda accord lx 2.2L automatic
Old Sep 29, 2015 | 05:31 AM
Turtlehead's Avatar
You can check the power supply to the horn by pressing on the horn and check for voltage with either a test light or a multi meter. If there is voltage then the ground is bad. I will try and check the shop manual this morning for further diagnostics on the switch, relay etc.
Old Oct 1, 2015 | 06:56 PM
As "Turtle" says, check for power to the horns - they are "hot" at all times and only sound when ground is applied.
Ground is applied via the horn switch, cable real, horn relay.
Old Oct 1, 2015 | 07:47 PM
stenny's Avatar
do you know what wire is the positive?
Old Oct 2, 2015 | 01:32 AM
The positive wires to both left and right horn are Wht/Yel, coming from under-hood Fuse No. 30 (20A).
ra1994gh
Dec 8, 2013 08:40 AM
whiskerz
Oct 24, 2011 10:11 PM
decadude
Jan 15, 2011 03:23 AM
fireblast713
Nov 1, 2010 02:06 AM
Rob_KCMO
Apr 18, 2010 12:05 AM
