'96 LX Fan Motor
Old Sep 1, 2010 | 11:57 PM
Originally Posted by trystendaycey
Where is the Power Window relay located? Is it in the interior? Thanks!
I must have missed something..... How did we go from a cooling fan issue to power window relay ?
Old Sep 2, 2010 | 12:37 AM
Desert, That sounds like Question #2 now
Old Sep 2, 2010 | 02:20 AM
That was from my suggestion. When my radiator fan relay went out, I switched it with the power window relay. My windows wouldn't work, but my radiator fan worked.
See pic for window relay location. It is right above the radiator fan relay.
Old Sep 2, 2010 | 01:23 PM
trystendaycey's Avatar
Okay PA and all, thanks for the help!
It must, by process of elimination, be the fan motor. Is there a way to tell, before I pull the fan shroud out, which fan motor I have? (There are no visible manufacturer's names on the motor since it is installed.)
It appears there is a Nippodenso and Mitsu...
Because of my schedule it would great to grab one on the way home from work and put it in tonight. I might not be able to pull the old one before the parts stores close.
Thanks!
Old Sep 2, 2010 | 02:39 PM
Both should work.
I looked up your parts at an oem site called hondapartsnow.com and it say the 96 LX ABS 4-door AT is a Denso motor.
Old Sep 2, 2010 | 04:22 PM
You are, indeed a SUPER Moderator! Thank so much... I'll keep you posted.
Old Sep 2, 2010 | 11:26 PM
  #17
if the fan has 5 blades it is a N/D ..........And motors are not the same , you cannot inter change them
are you getting both power and ground at the fan motor plug?? if yes, and motor does not work , you got a bad motor ,, if not , do not replace the motor you have other issues
as for the relay ,, like i said ,,i must have missed PA suggestion
CDJDM07
Aug 24, 2011 09:51 AM
BOBBY-25
Jun 5, 2011 02:40 PM
ramachan9
Jul 11, 2009 11:57 PM
Equalizer
Feb 20, 2007 08:57 PM
daddy
Feb 6, 2006 02:52 AM
