Problem with Low Beams
Old Oct 3, 2007 | 06:52 AM
03EXCoupeBoston
Default Problem with Low Beams
I am havinga problem with my low beams. It seams that almost every night that I turn my lights on either one or both are out. If I hit the housings than the bulbs go on and it is usually fine until the next day. At first I thought it might be my hyper-white bulbs b/c they are usually a higher wattage and can melt the housing/wires. That is not the problem since the bulbs I have are 55w (standard Honda wattage). So I am wondering what else could be the problem. Any suggestions or anyone else have this problem?
Old Oct 3, 2007 | 08:03 AM
falkore24's Avatar
Default RE: Problem with Low Beams
Signature, as noted elsewhere.
Do you have a relay kit on the lights? Check the connections since they can melt; usually with high wattage bulbs, but anything's possible. Also look to see that the leads are all of the way into the connector. There is a chance that when you changed the bulbs that you stressed the wires, pulling them back enough to disrupt the connection. Make sure that your grounds are solid also. A big 3 upgrade is cheap and can solve most grounding issues.
otrawj
Feb 27, 2014 03:50 PM
faceplant
Apr 4, 2009 07:35 PM
ThavionHawk
Nov 16, 2008 02:38 PM
RondaTheHonda
May 3, 2008 11:14 AM
jasoncook3
Dec 28, 2005 10:10 PM
