2002 Honda Accord - Odometer lights, Parking lights, and other lights not working
Old Apr 23, 2013 | 08:46 PM
csh217's Avatar
Default 2002 Honda Accord - Odometer lights, Parking lights, and other lights not working
Today I installed a new after market head unit in my car with an experienced friend. Everything is hooked up correctly and functioning. However when I turn on my parking lights they do not come on, also the dash lights to the tachometer, speedometer, fuel and temperate gauge do not come on. Also the lights to the automatic transmission (P,N,D4,D3,2,1) lights do not come on.
Note: Headlights do work as well as the odometer back light and clock light. Battery was unplugged during the entire installation of the head unit.
Does anyone think a fuse may have coincidentally blown after hooking up the battery again to test the newly installed head unit?
Old Apr 23, 2013 | 09:40 PM
robbierob02's Avatar
so your parking lights and instrument cluster dont work? i would first check fuses if you havent done so. did you use a harness adapter to wire your new unit or splice into the factory wiring?
Old Apr 23, 2013 | 10:31 PM
csh217's Avatar
I used a wire harness provided from Crutchfield. I dont exactly know which fuses to check because its such an odd collection of lights that are not working.
Old Apr 23, 2013 | 10:44 PM
Check anything that has to do with the lighting such as parking lights or instrument cluster. Like I said any lighting fuses check, don't know if the parking lights are fused together or fused left and right so just start checking there. Ive done plenty of stereo installs from simply head units to a full upgrade and have never run into a situation like this so my reaction would to be to first check all fuses before pulling apart and double checking my work
Old Apr 25, 2013 | 09:23 PM
I've moved this to the audio section but my fear is that "some how" the multiplex got blown......
Old Apr 26, 2013 | 05:30 AM
keep_hope_alive's Avatar
start by disconnecting and safely capping the orange and orange/white illumination wires.
Old Apr 29, 2013 | 11:30 AM
csh217's Avatar
Default Problem Resolved
So after calling crutchfield twice and relentlessly trying to diagnose my car, I finally discovered the problem(s). First things first, the orange illumination wires were bridged (which you are most definitely not suppose to do) so I unbridged the orange wires thinking that may have solved the problem. It ultimately did not, however it probably prevented future ones. After checking all the fuses, I finally found a blown fuse. The "Small light/license light" fuse was blown, so I replaced the fuse and everything was back to working order.
Old Apr 30, 2013 | 09:03 PM
good deal. i should have mentioned to check fuses AFTER you disconnect the illumination wires.
michael6593
May 17, 2012 11:18 PM
guy91
Jan 29, 2012 10:01 PM
jackmd
Sep 15, 2011 06:11 PM
Drpepper
May 22, 2007 12:20 AM
