2011 Honda Accord Radio on with no sound
Old Feb 15, 2021 | 07:04 PM
NWolfe's Avatar
Default 2011 Honda Accord Radio on with no sound
I installed an after market subwoofer and amp connected to the factory radio. It worked fine for a couple weeks, then the sound from all speakers stopped with the radio display still on. I checked fuses the next day, all were in tact, so I turned the radio on and all speakers played normally. I assumed a fuse had a bad connection and by pulling them, I fixed it. It worked fine for 2 days and did the same thing again.
I am guessing it has to do with the radio overheating and some type of protection in the radio causing the issue? Has anyone had this issue before?
Old Mar 24, 2021 | 09:44 PM
keep_hope_alive's Avatar
I suspect a slight short in the wiring you intercepted. You need to ensure that all connections are securely connected and fully insulated from any other wire and from any conductive service.
sdrywa
May 20, 2014 04:17 PM
edfrl
May 18, 2013 04:39 PM
ser498
Feb 12, 2010 07:50 AM
dannysm213
Jul 4, 2009 07:59 PM
kumar96accord
Jan 16, 2009 07:13 PM
