96 Accord + Sony Head Unit Loose Antenna Connect +Short
Old Oct 13, 2014 | 07:33 AM
JerryInOCMD's Avatar
Default 96 Accord + Sony Head Unit Loose Antenna Connect +Short
I've searched the forum, but haven't quite found an answer to my problem...
I've installed a Sony head unit in my 1996 Accord LX, and everything works fine until I try to plug the antenna lead into the head unit. The antenna connection seems loose, and every time I try to plug it in the radio just shorts out. I've left it unplugged, as I just stream music via USB connection, but I'd really like to be able to use the radio once in a while. The car was stock with a six-disc CD changer, and in-dash phone (both of which have been removed).
I'm stumped, and help would be greatly appreciated. Thanks.
Old Oct 13, 2014 | 07:01 PM
keep_hope_alive's Avatar
define "shorts out"? do you blow a fuse? does the head unit shut off?
nice finding a model with a changer and phone.
did you buy the Sony head unit new? what model?
some head units try to ground through the antenna.
Old Oct 14, 2014 | 05:35 AM
No fuses blow, but the head unit just shuts down. The unit was bought new, and is a model CDX-GT55UIW. Any idea why the antenna lead might not be a snug fit? I've looked at adapters, and it's definitely the correct type of antenna connection.
As far as grounding through the antenna, how would I remedy that? It's been so long since I did the install that I can hardly remember how (or if) it's grounded some other way. I'll have to pull the unit out and take a look. Ideally, should I just ground to the chassis somewhere near the HU?
Thanks so much for the advice, it's never bothered me, as I've got unlimited data on my phone, so I can stream to my heart's content. My recently-licensed son, on the other hand, has been burning through his data like a B***H. A working radio might help.
Old Oct 19, 2014 | 09:07 PM
i ground head units to the chassis using the ground wire in the harness. you can supplement with a ground wire attached to the chassis.
the antenna plug usually has some small metal fins that can be bent out to fit tighter.
did you use a metra harness adapter to connect the radio to the car's wiring? describe/draw the connections you made.
Old Oct 20, 2014 | 06:04 AM
Thanks. I'm off tomorrow, and will take a look. I'll also take a few photos of the connections that I made.
get'er go'in
May 4, 2010 12:33 PM
Linkin
Mar 14, 2010 05:24 PM
ughcord
Oct 19, 2008 10:43 AM
Gingi
Dec 4, 2007 05:11 PM
aatc20
Sep 14, 2006 04:28 PM
