99 Accord remote wire
Old Jul 9, 2011 | 03:33 AM
SunnySideDown's Avatar
Default 99 Accord remote wire
Where is the remote amp wire for this car? I have a amp with a high level input.
I found a PDF, if you google "Accord 1999 radio replacement" it should be on the first link.
On the PDF, PIN "I" is the "HONDA AMP GROUND WIRE" should I use that?
Old Jul 12, 2011 | 12:05 AM
keep_hope_alive's Avatar
Not the ground wire. Pin 17 which is missing the wire in the factory harness,
Old Jul 12, 2011 | 02:04 AM
My headunit only have 16 pins with the harness.
The headunit have 2 adapters, one already have a harness the other doesn't, is the 17th pin on the other side of the adapter? I mean next to it.
https://docs.google.com/viewer?a=v&q...SYcE7tZA&pli=1
Nvm I found
http://crutchfield.custhelp.com/app/...honda%20accord
so just add a pin to the 17th slot? I'm pretty sure I only got 16 pin slots on the adapter that is already connected with the harness, I'll check tmr
Old Jul 12, 2011 | 01:35 PM
sorry, my bad. i was referencing a 2005 for some reason.
Here is the remote wire addition i did to my 2001 Accord HU. We should have the same harness - mine is 20 pin.
If your head unit has a 16 pin harness, then i'm not sure which is the turn-on wire. could be one of the three "do not use" pins. you'd have to use a DMM to verify.
Old Aug 12, 2011 | 05:13 AM
My mistake, it only showed 16 pins on the pdf, but on the Head Unit it shows 20 pins. On the 20 pin harness, I used the "19th?" pin, the pin next to the "20th" pin.
When I use the 20th pin it only works on radio use.
Old Aug 14, 2011 | 10:45 PM
20th pin is power antenna then.
Old Aug 15, 2011 | 01:51 AM
Yeah, thanks for your help anyways.
Is there anyway for me to find a more accurate layout for the radio?
PAC AOEM-HON20 Add an Amplifier Adapter, Car Stereo Kits, Audio Wiring Harnesses, Installation Equipment, Electronics, Accessories & Adapters
Old Aug 24, 2011 | 12:37 PM
not really, there isn't good documentation on the radios. usually takes investigation.
jdubicki
Apr 16, 2008 08:30 PM
magiconthetire
Dec 11, 2007 09:13 PM
HONDA90
Oct 1, 2007 10:54 AM
2.2ex965spd
Mar 18, 2007 02:02 AM
2007accord
Feb 14, 2007 12:57 AM
