the front speakers is not working
Old Nov 29, 2009 | 01:24 PM
nak88
Default the front speakers is not working
Hi everybody!
My car 's model is Honda accord 2002. It has 6 speakers: 2 rear speakers, 2 front speaker in the door and 2 speakers on dashboard. But just 2 rear speakers work. I try to remove the cover and check the front speakers with another soure but it is still fine. Then i check the wire and it 's also ok. Can anyone help me this problem. Thanks a lot.
Old Dec 4, 2009 | 01:35 PM
t00fatt's Avatar
So when you hook up a different speaker to the front wring the speaker works, but the stock ones do not? And you need help figuring out what that means? Well if that is the case your front speakers are dead, prolly a burnt or broken coil.
Old Dec 29, 2009 | 12:10 AM
keep_hope_alive's Avatar
check your fader setting so it is not set to rear? losing both front mids and both front tweeters at the same time is suspicious and unlikely.
i don't understand what you're asking/saying about another source either.
GeorgeM
Oct 29, 2013 09:09 AM
Heinsite
May 25, 2012 11:07 PM
lapper69
Dec 1, 2011 07:29 PM
erock805
Jul 14, 2011 06:45 PM
ecko
Apr 17, 2009 04:45 PM
