Hooking Up Subwoofers to My Rear Speakers Using an Line Output Converter
Old Feb 17, 2011 | 11:08 PM
keep_hope_alive's Avatar
When the amp is on and head unit is off, the amp can damage speakers or subs from any electrical signal. The amp can pop or thump, mostly depends on the wiring, amp, and installation.
Old Feb 18, 2011 | 09:46 PM
troycifer's Avatar
since youre running your sub amp off your factory rear out id recomend getting an OEM bass reconstruction processor instead of a line out converter. it restores the bass frequencies that most factory head units take away. if you want outs for speakers and subs id recomend the mtx re-q
Old Feb 19, 2011 | 08:22 AM
good call. AudioControl has some nice products as well. if you get a processor/eq that has high level inputs and RCA outputs you can gain some additional bass output through level or EQ.
the bass restoration products can counteract the weak bass output from factory systems. some factory head units will reduce bass output when the volume is increased in order to protect the factory speakers.
StrikingAccord
May 2, 2020 06:38 PM
renzovc
Jul 21, 2013 10:57 AM
eduard
May 9, 2013 12:11 AM
kennilope
Mar 5, 2007 07:30 PM
