Install Stereo
Old Jul 16, 2011 | 05:22 PM
hondaman222's Avatar
Default Install Stereo
I have a 1989 Accord LX that did not come with a radio when I purchased it. I would like to install an aftermarket stereo. I would like to know if there is any special hardware needed.
Old Jul 16, 2011 | 09:36 PM
keep_hope_alive's Avatar
you'll simply need the Metra 70-1720 wire harness adapter. the factory radio is single din, but you need the mounting brackets off it to mount an aftermarket radio in - maybe a salvage yard?
Instructions:
http://www.accordinglydone.com/data/90-93accord.pdf
Old Jun 8, 2012 | 01:32 AM
Salvador A.J. Williams's Avatar
i am facing nearly the same problem as you. i just got a 1989 honda accord lxi coupe, from a junk yard, and someoen has stolen the radio and did a number on the wires for the radio, they also had taken the front right speaker.i have a radio to put in there its just a metter of connecting all the wires again so i can plug it up. but i still need a new speaker. anyone with tips or advice on this , i am very grateful.
Old Jun 8, 2012 | 07:47 PM
neophyte's Avatar
I would suggest buying a new factory harness. matching those wires and getting the adapter to put in the new stereo.
as far as buying a new speaker, find out the speaker size. crutchfield.com can help you with that. then buy a new one.
Old Jun 10, 2012 | 02:57 PM
any new speakers you get will come in pairs. that's not a bad thing. it depends on how much money you are willing to spend fixing the problem.
a new harness is the best route, but it is tedious work. in that case, you'd by both the 70-1720 and the 71-1720. the 71-1720 would be wired to the car wiring. the 70-1720 would be wired to the new head unit. then the two plugs would connect.
Old Jun 10, 2012 | 09:37 PM
Great info men..that should help him out with the project he's going to be doing.
Cobrajay
Oct 3, 2007 10:36 AM
drewdin
Jul 4, 2007 10:08 PM
jprez1980
Apr 3, 2007 02:57 PM
wcbzero
Mar 13, 2007 08:05 PM
SilverBlueVTEC
Jan 7, 2006 11:11 AM
