please please someone help
Old Mar 31, 2008 | 08:55 AM
BIGWILBO
Default please please someone help
please please please can someone help? i have just bought a 2003 honda 2.4 vtec accord and i couldnt get the sat nav to stay on ( when i started the engine the screen would go blank and flash off and on every now and then) however when i took the dvd out the sat nav wouldnt work but i could use the other controls on screen. so i went on the net and found a way of updating the sat nav so i did it and now all i have is a green progress bar on screen that never moves. any ideas how i can reset it???????
Old Mar 31, 2008 | 10:58 AM
sir_nasty's Avatar
Default RE: please please someone help
to reset it you'll probably need the radio code.... if it's not in the glove box and you don't have it then you could probably get it from a honda dealer with your vin code.... Pull the negative battery cable for about 5-10 minutes and that will reset everything.
Old Apr 1, 2008 | 06:29 AM
BIGWILBO
cheers bud i was starting to think it was going to be a expensive mistake lol
Old Apr 1, 2008 | 09:58 AM
BIGWILBO
sorry bud tried it three times now doesnt seem to be reseting anything apart from radio sations and my clock any more ideas?????
Old Apr 1, 2008 | 11:24 AM
sir_nasty's Avatar
If it's still doing the same thing then chances are it's stuck in an update phase and that's written into memory.... you may need a dealers help.
Old Apr 1, 2008 | 11:34 AM
t00fatt's Avatar
Yea it sounds like your BIOs may be corrupted or some other software related problem. You may have to take it to the dealer to get reflashed, if they can even do that there. Jhowkins knows the system in and out so maybe he knows a way to reflash it.
EDIT: Spelling
Old Apr 1, 2008 | 11:50 AM
00AccordLX5spd's Avatar
Registered User
There was a recall on the 7th generation head units. You may want to check and see if yours was recalled. Honda may replace it for free.
Old Apr 5, 2008 | 07:57 PM
pham9006's Avatar
honda replaced mine for free cuz i was still under 70,000 miles...
some kind of warrent im not sure..
cyeezy
Jun 11, 2013 12:26 PM
stephen94accord
May 20, 2009 09:24 AM
kim1724
Jul 25, 2007 08:54 AM
Sparco_racingVTEC
Jul 26, 2006 09:11 PM
