Paint job help
Old Jun 15, 2011 | 10:04 AM
crshbandit's Avatar
Default Paint job help
I just recently painted my 92 Honda Accord. I color matched the paint at NAPA to the original color and painted the entire car except the very top, which didn't really need it. I also sprayed 2 coats of clear coat on the car after the color coats. I didn't think I did a bad job for not really knowing what I was doing. However, now the car has a dull look to it, even after spraying the clear coat layers. How do they get that mirror finish on professional paint jobs? I would like it to look more like the top of the car which has more of a glossy mirror finish. Do I need to buff the clear coat now or is it just my "less then professional" paint job? I figured there has to be some body shop guys out there that can give me some more info. Thanks for any help!
Old Jun 18, 2011 | 12:37 PM
Comon Body Shop and Auto Painters..I know your out there..Give this member a good answer and of course a correct one..
Old Jun 19, 2011 | 10:43 AM
crshbandit's Avatar
Thanks wheelbroker, Still waiting. I may have to drive the car into a body shop and have them snicker at my paint job to get some advice. I know they are just going to tell me to let them do it over! I don't have 500 bucks to spend so for now I drive my dull Accord!!
Old Jun 19, 2011 | 04:04 PM
I did same thing on my 94 EX and suspect the problem is spraying too much clear coat per pass. I think it's got to be several very light passes.
Old Jun 20, 2011 | 09:53 AM
crshbandit's Avatar
what about buffing out the clear coat? Should I get ahold of a power buffer and use some sort of buffing compound? Just wondering.
Old Jun 20, 2011 | 06:18 PM
My clear coat was too rough to buff out, but if your coating is only fine bumps you might have success. You need a flat smoothing bar that reduces high points and not the valleys. A buffer may not do this type of buffing. I would think a flat sanding tool w/ very fine sandpaper.
Maybe some painting expert will chime in. I proved I don't belong anywhere near that category.
Old Jun 26, 2011 | 12:00 AM
bigpat's Avatar
Almost A Senior Member
Sounds like you need to wet sand/ color sand the clear coat. Use 1000 grit wet sandpaper and do a small test area for practice...This is done only by hand with a very wet surface and soaked sandpaper. There should be plenty of info on this...Do a google search for "How to wetsand/ color sand your vehicle". You do this before you try buffing the finish to remove orange peel or eggshell spray finish. When it is time to "buff" the finish, use a product called "Cutting Compound" applied with a random orbital polisher. Again, do a small test area first, and take your time...It is a small car and will not take all day.
mestnf
Jan 17, 2008 07:22 AM
Cody Is Cool
Apr 7, 2007 08:29 PM
louisville_slugger89
Mar 3, 2007 07:28 PM
dj.fli4rt
Nov 17, 2005 03:54 PM
Shocker
Jun 24, 2005 08:41 PM
