Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
HVAC Code(s)
Old Jul 17, 2016 | 03:34 PM
Default HVAC Code(s)
This is the information from an 03-06 Accord Shop Manual I found online.
1. Turn the ignition switch ON (II).
2. Press the AUTO button and then the OFF button. Continue to hold buttons down for 1 minute.
If there are any problems in the system, the temperature indicator will light up the segment (A through Q) corresponding to the error. The temperature indicator will then alternate every second between the displaying "88" (all segments lit) and the error code segment (A through Q).
NOTE: The system will only display the DTC when the AUTO and OFF buttons are pressed. If you release the buttons, the display will go blank. To return the display, simply press the AUTO then the OFF buttons again.
Attached Thumbnails HVAC Code(s)-pahonda-5547-albums-pics-2243-picture-gauge-4454.png   HVAC Code(s)-pahonda-5547-albums-pics-2243-picture-climate-control-system-8407.jpg
Old Jul 17, 2016 | 03:37 PM
This is the procedure for 03-07 Accords without climate control.
1. Turn ignition switch OFF.
2. Turn fan switch OFF.
3. Set temperature control dial to Max Cool, then push the mode control button to select Vent.
4. Turn the ignition switch ON (II).
5. Press and hold down the recirculation control button.
6. While holding the button down, press the rear window defogger five times within 10 seconds. The recirculation indicator blinks two times, then the self diagnostic will begin.
If there is any problem in the system after self-diagnostic is finished, the recirculation indicator will blink Diagnostic Trouble Code (DTC) 1 through 6. If there are any problems in the evaporator temperature sensor circuit, the A/C indicator will blink DTC 7 or 8.
If no DTC's are found, the indicator will not blink.
Attached Thumbnails HVAC Code(s)-pahonda-5547-albums-pics-2243-picture-hvac-no-climate-control-7408.jpg   HVAC Code(s)-pahonda-5547-albums-pics-2243-picture-hvac-codes-no-climate-control-7409.jpg
Old May 1, 2020 | 12:25 PM
DErh58's Avatar
These didn't work for me.
Don't know why.
I tried both. There was no response at all.
2005 Accord EX
Old May 2, 2020 | 03:26 PM
DErh58's Avatar
Ok. So after some research, This is the guide I found which worked for me.
Accords with climate control
2. Set the driver's temperature control dial or button on MAX Cool.
3. Press and hold the OFF button.
4. While holding the OFF button, press the rear window defogger button five times within 10 seconds. The self-diagnosis will begin..
Mine had no problems and hence no codes.
Hope this helps somebody.
2005 Accord EX.
PAhonda
Sep 14, 2016 09:11 PM
03v6ex
May 18, 2014 05:56 AM
discohouse
Sep 18, 2013 07:36 AM
cati98
Sep 28, 2011 03:25 PM
JEB0007
May 14, 2011 02:50 AM
