Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
Transmission Cooler Install DIY Guide
Old Jun 2, 2015 | 12:49 PM
mikewohlwend's Avatar
What did you use to add the transmission temp gauge?
Old Mar 21, 2018 | 02:02 AM
Eran Teitelbaum's Avatar
do you have to bleed the air in the system after such a job or after you disconnect one of the hoses?
Old Jun 28, 2020 | 01:42 PM
Meccano's Avatar
Hey guys,
Hope you are all well.
I'm on my 2nd trans as well.
Installed a reman unit and the trans still isn't smooth as it once was. So changed the reman trans for another reman one and still the same...
Got a used TCU to try and no change...
So I am trying to figure out what goes on with my trans... If anyone has seen the case and has an idea, I'm all ears!
Hopefully, I can fix it and would like to add an additional cooler and possibly update components (I saw that there were som "upgraded valves" for our trans but don't know if it's just B.S or if the mod is really effective.
Any feedback from the brands you bought? any recommended ones and which to avoid?
Thanks for your suggestions.
kenwood guy
Mar 23, 2013 09:15 PM
Accordtoy
Jan 31, 2013 11:34 AM
markus9175
Mar 27, 2009 10:35 PM
cengland84
Oct 28, 2008 01:20 PM
