2006 Honda Accord V6 Engine Question
Old Jan 3, 2008 | 06:41 PM
HondatechAV6's Avatar
Default RE: 2006 Honda Accord V6 Engine Question
valves typically get tighter over time. this doesn't make noise. only loose valves make noise. tight valve can cause misfires and destroy cylinder heads. we adjust valves at the 105k at our dealer.
Old Jan 13, 2008 | 01:58 PM
tubasteve's Avatar
THE FINSIH WONT HURT ANYTHING. MIGHT WANT TO CHEK THE VAC. LINES FOR THE MOTOR MOUNTS, FRONT AND REAR SOFTEN AT LOW RPM, NO MATTER WHAT THAT CAR IS COVERD AT THE DEALER 36K MILE, 36 MONTHS(3 YEARS)
Old Jan 22, 2008 | 05:25 AM
YeuEmMaiMai's Avatar
ORIGINAL: HondatechAV6
the vibration at idle is the immense power you feel coming from a superior powerplant. but seriously, some vibration is considered normal, youcan probably only feel it in the steering wheel, and it goes away if you grip it tightly. i wouldn't worry about it unless it's a hybrid accord.
valve adjustment isn't recommended until 105,000 miles, and even then it requires very little to no adjustment. the rocker arm assembly uses a roller bearing, it's so nice.... i love it.
lol you had me laughing at that one my j32a2 does notcause any vibration .........my stuff is as sooth as a knife through warm butter.......lol
things that can cause some vibration is engine idle low due to drag caused by the accessories most common culprit AC compressor. Gas engines make NEXT TO NO POWER at idle
Old Jan 22, 2008 | 08:56 AM
falkore24's Avatar
Engine and tranny mounts ..... also vacuum lines.
Jaffa
Mar 15, 2015 05:52 PM
waqarali
Oct 11, 2012 03:01 AM
mgamer20o0
Jan 1, 2010 01:45 PM
saladfingers
Sep 30, 2009 08:59 AM
greg9442
Feb 3, 2009 08:41 PM
